Is it possible to reset the AppInsight for SQL Template to default settings it came with? Maybe download and import the default template again?
This should help:
SolarWinds Knowledge Base :: AppInsight Templates are not available.
This will re-import the default AppInsight Templates.
http://www.solarwinds.com/documentation/en/flarehelp/SAM/default.htm#../../sam/content/SAMAdminGuide-EditingtheAppInsigh…
Not a reset, but you can edit it. HTH.
The template was edited previously and I want to start fresh by possibly importing it as a new template.
Perhaps SW has a copy of the default template file?
I was able to run the command but it returns "Template already exists". I was also unable to delete template from SAM interface - delete button is grey'd out. I don't see any switches to force overwrite.
c:\Program Files (x86)\SolarWinds\Orion\APM>.\APMTemplateImporter.exe -includeRe
adOnly .\DefaultTemplates\AppInsight*
SolarWinds Server & Application Monitor Template Importer
Importing Read Only Templates
Found 2 template files.
Template files to add 2, legacy template files 0.
Processing file ".\DefaultTemplates\AppInsight for Microsoft Exchange.apm-template"
A template named "AppInsight for Exchange" already exists. This template will not be imported.
Importing 0 new template(s).
Processing file ".\DefaultTemplates\AppInsight for SQL.apm-template"
A template named "AppInsight for SQL" already exists. This template will not be imported.
Please open a ticket with Support. Submit a Customer Service or Technical Support Ticket - SolarWinds
Yeah, AppInsight templates aren't meant to be deleted or copied the way regular templates are. All we can really do is give you the thresholds from the default template and you can reset them manually.
