Does someone able to download the configuration from the Alcatel 7750 & 7450 devices ?
Hi cradaelli,
You might want to check the following device template:
Alcatel 7210-M-1.3.6.1.4.1.6527.6.2.1.2.2.1.ConfigMgmt-Commands
Please let me know if you need instructions to make this device template work with your devices.
Regards,
Jiri
Yep!
It's working for 7750 & 7450
Thank you!!!
Jiri...
I have 30 X 7210SASM into my environment and I was wondering if you can help me to create the config change templates. I have the most updated solar winds products. Also in my environment I do have alcatel omniswitch 6855 and 6850. I want to be able to schedule downloads of the alcatel configurations once a month or when a network tech mae any changes to it. Your help is much appreciated.
Thank you !!!
Hi pstoian,
In order to download configs, you don't need config change templates but device templates. The one referred above (Alcatel 7210-M-1.3.6.1.4.1.6527.6.2.1.2.2.1.ConfigMgmt-Commands) should work for your devices.
If you have NCM 7.4 connected to the Internet, then you can import this template directly from the web console.
Go to Settings -> NCM Settings -> Device Templates:
Assign the template to the devices you want:
Jiri,
It's working perfectly for the SASMs. Thank you for your guidance.
I have also several Alcatel Omniswitches 6850-48X and 6855-14X. Do this templates will work with these models ?
I'm not sure about the Omniswitches. Give it a try and come back if it doesn't work.
