Gents,
Running 9.0 SP1. Seems that the UDP stopped for no reason this morning. Anyone got a clue how to analyze why? Also, when trying to start the UDP on the server it takes several minutes before it's up. Is this normal?
The Universal Device Poller uses the Job Engine and the Job Scheduler to perform its tasks.
The issue is probably related to those two services. Ensure that the Job Engine and the Job Scheduler are running.
You should first check the UnDP log files:
\Program Files\Solarwinds\Orion\UniversalDevicePoller.log
If you see an error then it might lead you to the Job Scheduler and Job Engine log files:
\Documents and Settings\All Users\Application Data\SolarWinds\JobEngine\Logs\
Review as well the windows events on the server to check if there are any errors.
Do not hesitate to open a support ticket if you need.
Yann
Found this - which probably not is a good thing:
2008-11-20 10:20:37,471 [Scheduler] ERROR SolarWinds.JobEngine.Scheduling.ScheduledJobStore - Exception caught while initializing ScheduledJobStoreThe database file is larger than the configured maximum database size. This setting takes effect on the first concurrent database connection only. [ Required Max Database Size (in MB; 0 if unknown) = 257 ]
How can I shrink this?
You can replace the JobEngine.sdf file by the JobEngine - Blank.sdf one.
They are stored there C:\Documents and Settings\All Users\Application Data\SolarWinds\JobEngine\Data .
Stop all the Orion services before to replace the sdf db.
Once done, Start first the JobEngine service then the JobScheduler and finally the other Orion services.
monitor the log file where you found the error and check if your UnDP restart gathering data.
My UnDP stopped polling at 2:51AM this morning (Running Orion V9.1 SP4).I'm seeing a whole bunch of these in the NPM.BusinessLayer.log:
2009-02-10 02:28:27,853 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!2009-02-10 02:28:57,872 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!2009-02-10 02:29:57,896 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!2009-02-10 02:30:27,915 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!2009-02-10 02:30:57,951 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!2009-02-10 02:31:27,939 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!2009-02-10 02:31:50,356 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!2009-02-10 02:32:27,987 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!
Same thing here:
C:\Documents and Settings\All Users\Application Data\SolarWinds\JobEngine\Logs\SolarWinds.JobEngineService_v1_1.txt
2009-02-09 17:36:35,712 [ScheduledOperations] ERROR SolarWinds.JobEngine.ScheduledOperationManager - Woke up too early!2009-02-10 02:31:38,383 [ScheduledOperations] ERROR SolarWinds.JobEngine.ScheduledOperationManager - Woke up too early!2009-02-10 02:36:38,518 [ScheduledOperations] ERROR SolarWinds.JobEngine.ScheduledOperationManager - Woke up too early!2009-02-10 02:41:38,605 [ScheduledOperations] ERROR SolarWinds.JobEngine.ScheduledOperationManager - Woke up too early!
Same thing here (except nothing from today):
C:\Documents and Settings\All Users\Application Data\SolarWinds\Orion\APM.BusinessLayer.log
2009-02-09 08:19:09,490 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!2009-02-09 17:23:07,119 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!2009-02-09 17:23:37,147 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!2009-02-09 17:24:07,174 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!2009-02-09 17:24:37,202 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!2009-02-09 17:25:07,229 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!2009-02-09 17:25:37,257 [Scheduler] ERROR SolarWinds.Common.Utility.Scheduler - Woke up too early!
<EDIT> I've lost SNMP access to this device (the only one I'm polling with UnDP) </EDIT>
Does that mean your issue is more or less solved till you get SNMP working back on this device?
If not then I am not sure if your issue is related to the JobEngine.sdf or JobEngine35.sdf databases.
Do you have any errors in the \Documents and Settings\All Users\Application Data\SolarWinds\JobEngine\Logs\SolarWinds.SchedulingService_v1_1.txt log files?
This is the last one you did not check.
Do you have anything in the System and Application events around 2:51am?
I have never been able to correlate this error message with an issue in the past.
