Is there any way to insert a URL in a map, and when I access this URL, mantain
the Orion banner ?
Ok here is what i have done in order to achieve this from Network MAP.
1. Create an external website.
Login to Orion website> Settings > External Website .
URL: http://www.cnn.com
2. Now Add an Object in Network Atlas
Right Click on Network Map > Add Object > Right Click on Object > Properties > HyperLink >
now in hyperlink i have added something like this.
192.168.168.168/.../External.aspx
( You can add server name insted of ip if you have resolved this)
orionservername/.../External.aspx
Save the map and refresh you webpage . click on the Object on the Network Map . now this will open in Orion website
and keep the Orion website logo and tool bar in browser.
let me know if you require further information .
Hi
Can you provide a little bit more information what you are going to achieve ?
You can embed URL in jpg and use image in Network Atlas map . Once you will click on image it will bring you to that URL.
Regards
When I click in a map, I want go to that URL, but maintaining Orion banner in top page.
Is that URL is out of Orion NPM website ? for say google or cnn ?
Yes, that URL is out of NPM page.
Thanks a lot.
I'll try this on monday.
Regards.
Just checking did this helped ?
Banner is ok, but I cannot open the web page:
I think HP BladeSystem OA webpage is too complex to be opened inside Orion´s web page.
Ok so its just the URL need to be configured. Have you tried something CNN ? just to be verified ...
