Are these files still the only log files for the NPM nightly maintenance? Is this where I would go to see errors in the nightly maintenance?
C:\Program Files (x86)\SolarWinds\Orion\NetPerfMon-Maint-'CURRENT DATE'.log
Bump.
Also \ProgramData\Solarwinds\Logs\Orion\swdebugMaintenance.log
Thanks, netlogix!
I found swdebugMaintenance.log on my W2K3 system in:
C:\Documents and Settings\All users\Application Data\Solarwinds\Logs\Orion\swdebugMaintenance.log
Still haven't found NetPerfMon-Maint-'DATE'.log since the upgrade to 10.2.2. It was last seen in:
c:\Program Files\Solarwinds\Orion
So it must have moved, died, or is no longer used.
The swdebugmaintenance.log holds the database maintenance logging for NPM, UDT, SAM, and others with the exception of NTA. NTA's log is NTADatabaseMaintenance_BusinessLayer.log which, in Windows 2003, would be in C:\Documents and Settings\All Users\Application Data\SolarWinds\Logs\NTA.
Thanks, mharvey.
What I'm finding is that the mainternance is indeed running. But I believe this is a separate maintenance from the maintenance setup via the Database Managet via Database Backup Schedule. That maintenance also compacts the DB, which I find has not happened since our upgrade to 10.2.2., nor do the backups appear in the directory specified. The Properties on the NPM DB show Total Space Usage of 58.6GB, but Data Space Usage of 15.6 GB.
I can compact the DB, but during the middle of the day, this means data logging to SQL is disabled, something we do not want.
I'm thinking it could be because one of our other admins setup a true SQL schedule that somehow conflicts with it. But I'd like to find evidence.
Wouldn't the Maintenance scheduled by the Database Manager show up in the NetPerfmon-Maint-'DATE'.log?
We really need better names for all these maintenance operations.
