Do the Solarwinds NPM availability reports consider maintenance mode while calculating node availability/uptime?
If you unmanage a node it skews availability, because during the unmanaged time we do not poll and so the total number of intervals during the period becomes inconsistent.
For example, over a 24 hour period:
If the node never goes down outside maintenance, 100%
If the node was down for 144 minutes, up the rest of the day, 90%
If the node was down for 144 minutes, up the rest of the day, but got unmanaged for an hour when it was supposed to be up, 89.56%
Unmanaged objects can be pretty wacky in terms of uptime reporting unfortunately, haven't figured out a good method to balance it all out myself.
Hello,
Thanks for the response. Just so I’m clear, let’s assume I put a node into maintenance mode for 90 minutes (using the “schedule”, then mute option) during a scheduled outage...are those 90 minutes are disregarded when calculating availability?
Best regards,
Ade
Mute has no effect on availability calculations. If the node goes down during the mute period is will be calculated as normal. There's no built in provision in Orion to calculate availability outside of scheduled maintenance windows, only the raw availability.
OK...thanks very much. Is there any way to run a separate report for the maintenance windows?
reply from mesverrum in Network Performance Monitor - View the full discussion
Reply to this message by replying to this email, or go to the message on THWACK
Start a new discussion in Network Performance Monitor by email or at THWACK
Following Solarwinds NPM availability reports in these streams: Inbox
To find answers to your questions and up-to-the-minute product info, please visit the THWACK forums.
This email was sent to the email address used on your THWACK account.
Unsubscribe
Change Preferences
SolarWinds, 7171 Southwest Parkway, Building 400, Austin, Texas 78735
I was wondering the same thing.
