How do I enter command to display Custom Properties I have defined? Do I have to pick that out of the database?
We have that as an open enhancement in the system.
Have you seen this blog post I did here
Thanks. Yes and it is a big help listing the variables in one location. It did not address the "Custom Properties" variables that we create. I did enter them in the same manner and they did not appear to work. The when I looked at it again this morning the contents of the "Custom Variables" were present in the Map Tooltip Hover-over.
It would also be great to be able to 'customize' the hover-over pop-ups in other display locations other than maps, such as in the All Nodes - Tree or alerts section.
Thanks again for the help.
Hi, is this still a planned enhancement, or is it available? If so, what version?
Many thanks!
L
I assume you mean to extend the hover over popups to all the website? If yes, then the answer is this is still an open enhancement
