Edit Network Maps On the Orion Map Maker , But in the WEB browse the Map sometime disappear sometime OK
What Problem ?
what does the web site show when the map is missing?
Can you post a screenshot of what you are seeing?
I clock Top 10 or Events or Overview button then review Home the maps disappear
THANKS every programer
good week!
I am having a similar problem where my map disappears after and then a reappears after a few minutes, leaving only the following message behind when the map is not there. Any help would be greatly appreciated.
Cannot load Network Map from "E:\Program Files\SolarWinds\Orion\Maps\CISCOVPN.OrionMap"
I sometimes get this as well. if I do a refresh, it comes back, but need to get that resolved.
Re-run the website portion of the configuration wizard, this should help.
