I can't seem to get the graph to show the data in terms of Mb
Nobody knows how to do this??
What does the final chart look like?
Obviously if this switch only had 58k free memory, we'd probably be in trouble. Not so much if 58Mb
It apperas that when you choose "Bytes" for the Y axis the graphing engine automatically converts to KB, MB, TB...
The data above only fills the KB range so KB is appropriate to display.
I guess I am not sure what you mean. The free memory on the switch is measured in KB.
_Switch_.1 # sh memory
System Memory Information
Slot-1 Total DRAM (KB): 262144
Slot-1 System (KB): 7480
Slot-1 User (KB): 196152
Slot-1 Free (KB): 58512
I wouldn't mind if the graph shows KB, except the KB value is wrong. I want to be able to show the correct value, whether it be MB or KB on the graph, but I don't seem to have the option to make this work.
