We never trialed VMGR and cannot get rid of this error.
How can we make this go away? Its maddening.
Eval banner - why??
it is not reading your license file, or the license file is bad. Note: it only reads the license file when it is booting up.
Thanks, but, the problem as I mentioned, is we have never installed this product trial. Ever.
Well, it would certainly help if I had read your original post correctly
Just to be clear, you never installed Virtualization Manager, eval or otherwise? For whatever reason NPM thinks it is/was installed.
Silly question - can you go into the server's program manager and check out what the server thinks is installed?
No trace of VMan anywhere...
I think it's time to get SW support involved. I hate to think that you'll have to rebuild your server just to get rid of the message, but at this point that's all I've got. Hopefully they'll have a better idea.
