Have the caveats been sorted out for running NCM on Windows 2008 with version 6?
Jon
Thanks for the responses. I have opened a ticket but it looks like I'm stuffed. I will have to go back to a 2003 server as the local security guys will not allow that (or virtually any other) setting to be disabled
I too would like this answer, I am trying to move everything to 2008 and am just waiting for full support.
I moved to NCM V6 and running 2008, had no problems so far.
Have you noticed any issues when trying to create scheduled jobs? I keep getting an error that I have to be an admin but I'm logging on as an admin. Then it locks me out of scheduled jobs. I have to delete the job I tried to create from the task scheduler via the registry to get access again.
Any thoughts? I did not have this issue with v 5.5.
Hi drummer--
I'll let the PM know about this issue.
M
Drummer - I haven't heard of this issue before. Could you open a support ticket?
--Christine
Did you get a fix for this - I have the same problem
I figured out this issue. The only way to get it to work is to disable this security setting: Network access: Do not allow storage of credentials or .NET Passports for network authentication. Apparently, this is a known issue with Microsoft and how they’ve redesigned the task scheduler in 2008. Once that setting is disabled, scheduled tasks work fine.
