I have this table showing our Dell Equallogics's temps, but I just want the 2nd and 3rd rows to be seen, possible?
Bump - I'd like to know too if it's possible to hide the "Label" column from a tabular UnDP.
I assume you mean second and third column, not row right?
First column to be removed and keep the second and third.
Can the column order be changed?
I second this question. I have similar problem with the way it shows in the table. Can't find any way to rearrange the column (ex. change column B to C or vice versa)
I have not found a way to reorder the columns, Brandon can we make this a feature request?
JB
It is already defined in the system, I will add ya'll to the request
