I upgraded npm but get this error on netflow when added my wlc. I also do not see any stats
is receiving flow data from unmonitored WLC node
Hello Marnell,
I believe these KBs will help you resolve your issue:
Unmonitored NetFlow interface - SolarWinds Worldwide, LLC. Help and Support
Unmonitored interface automatically added - SolarWinds Worldwide, LLC. Help and Support
I already had the options checked. Still not seeing data from the WLC like I do on my ASR. Can I use the same port 2055 or should I use a different port?
You still use port 2055. Did you also set the "Netflow Monitor" under the WLANs, QoS tab?
yep
What model WLC are you using?
cisco 5500
Yea they are all 5508. Would this a cisco issue or something SW could get working with a new patch or update?
It looks like a Cisco issue. NBAR2 and Flexible Netflow for Cisco WLC 5508
