What 'type' (echo, ftp, etc.) can be used to test the time to transfer 1 MB worth of data? Ideally, this would be configured to occur once per hour.
The more details, the better.
Thanks!
Hi nchabra,
I believe this should be ftp. If you want to manually configure this, the link below woulld be very helpful:
http://etutorials.org/Networking/network+management/Part+II+Implementations+on+the+Cisco+Devices/Chapter+11.+IP+SLA/IP+SLA+CLI+Operations/
With this knowledge, you can configure this easily via IPSLAM as well. Hope this helps.
Let's say we wanted to do some type of ping which equates to 1 MB every hour from source 1.1.1.1 to destination 2.2.2.2?
Here is what I have so far:
ip sla monitor 160 type echo protocol ipIcmpEcho 172.27.254.1 request-data-size 1500 owner vnetdisc:Source-Dest-ping frequency 3600
ip sla monitor group schedule 2 160-185 schedule-period 300 start-time now life forever
Please let me know what is missing.
Ping is probably not a good choice to show data transfer rates. I would use FTP.
Defining HTTP FTP get operation CLI with absolute path. Get the file /home/user/test.cap
Defining HTTP FTP get operation CLI with relative path. Get the file /test.cap
The idea is to monitor network speed without actually transferring anything. For example, an extended ping of the appropriate 'Repeat count' and 'Datagram Size' should emulate a 1MB transfer. Is there something close to this with IP SLA?
You could do that but I don't get the point of why you would. If you are going to measure 1 MB of pings why not just measure the transfer of a 1 MB file? ICMP never carries user data so you would only be measuring your network's ability to move pings.
