I am running NPM v10, is their no way to search the actual message of the Syslogs?
I am trying to find specific TCP streams from a firewall, is this not possible?
Where are you trying to do this, in the web console or the win32 app?
Either, Does not matter.
Neither seem to have the option to do so.
What version are you on? In the web you can search or filter on IP Address, Severity, Facility, Message Type and Message Pattern
v10
I do not need to be able to search the IP address that the log is coming from. I need to be able to search the message part of the syslog for an IP address that the firewall is blocking or allowing.
Have you tried searching against message pattern?
