NTM does not find some devices. I input 14 IP's into free form IP discovery, NTM finds 13 and leaves out 1. I can ping the missing IP, but NTM will not find it. Tried a new scan on just the missing IP, still could not find it?
Stumped
Here are some basic questions that you may have assumed, but I'd like to cover them anyway:
I have tried it all. Subnet, IP Range, Free form IP, Seed router, checked for the IP in Device tracker, etc. I can ping the IP but NTM does not find it on a scan. It makes me wonder what else it can’t discover?
The device in question is a UPS, there must be something peculiar with it.
Good, I'm glad to read you've covered the basics.
All of my UPS brands (APC, Eaton, Best, Merlin-Guerin) have a "Security" section to enter in allowed IP addresses of pollers--it works exactly like an ACL or White List. Does your UPS have a place in which to configure itself to allow polling from your NTM device? And if so, is it set to allow snmp from your NTM?
That is good to know thanks! I will check with the contractor who dropped that system in. It’s a 2 way radio console system and these guys do not know IP.
A UPS is often treated like an after thought--a stupid device with which few "important tasks" can be done. It just does it's job--or it fails. Hopefully you've got a maintenance program in place to have it tested & monitored and maintained with replacement batteries on the manufacturer's recommended schedule. If not, then a UPS can cause more outages than it prevents.
Ideally a UPS will automatically go into bypass mode (bypass the batteries and use building power) when the batteries fail. Plus it should have the ability to be put into bypass mode both locally (via a dedicated wall-mounted toggle or rotating switch) and remotely (via the network management card). This ensures the devices it powers will stay up when the batteries are being replaced.
But all of my newer UPS's are also a serious security threat once they're on the network--because anyone with remote access into them can shut down power to their outlets. Talk about your basic DOS attack! What could be more serious than someone shutting down your equipment through your UPS?
If you connect UPS management cards to the network, UPS snmp/mgmt cards must have adequate protection in place. But you are responsible for enabling it. At a minimum, a UPS should be protected from remote attacks in these manners:
