I have created custom properties under my nodes for entering in maintenance contract numbers and serial numbers.
Is there a way to make these custom properties a mandatory item so when others add nodes it forces them to input this information?
Sounds like a feature request
Because I think this functionality is not yet present on the most recent version of Orion
Though you can "mandate" other user to fill it out otherwise you'll break their neck
I'd love to vote for this request!
Feature request has been made at:
Thanks for the replies.
i would like this and also the pull downs when adding a node with the various current values of a custom property but with the ability to enter new text too of course
This would be a nice feature. Also, as I have mentioned before having a drop down option: the ability to pre-define a list of options that are then selected from a drop-down. This would reduce my concern about people mis-typing something resulting in no alerts on an issue.
Thanks for the feedback, we have heard this from others and have this already defined in our feature request system, I will append everyone's name to it
Can you put my name down for both features (mandatory and drop down box)
