Hi
When I push “refresh” does the program looking for changes in the object I’m on, or the hull DB??
/SJA
Can you add supporting screenshot?
Sure
When I refresh 1 Object or all its take the same time..
The q: is the Atlas is looking for changes only in the object i mark or the hull DB??
My experience has been that it will refresh the entire Atlas application with the database no matter what is highlighted.
Now the Question is WHY???
Is any body from SW can tell how the Atlas can scale ???
The only time you should need to refresh the Atlas is if you've added something new to NPM or APM since you fired up the Atlas. It sync's the first time you open the application and everything is allocated on the left side.
Where is the problem with scale?
Well why should you sync the entire database for 1 node???
The software /DB need to sync on the node i just chose ?
you scale much better when the software does not waste resources.
