cflowd should work without any problems. NTA requires the fields discussed in this KB. My recommendation is to turn it out and find out :-)
Can you tell me the exact platform you are looking to configure this on so I can try to help point you in the right direction for configuration assistance?
Mav
The OS Configuration Guide has good information on how to configure cflow. I couldn't quickly find this on Alcatel's site (I don't have a login). But if you do, the CFlow sections starts on page 430 (good config info starts on 443)
If you don't have access, you can look at it on this page: http://www.pdfio.com/k-246128.html#
Two tips are:
Thanks! We will try it and hopefully it works.
Hi! I have a problem regarding configuring cflowd on my 7750 SR and I hope I might be able to find answers here since I can't find it elsewhere.
Is there a function to designate the source which cflowd is sent to the SolarWinds server? Something like "ip flow source" in cisco catalyst devices. I am having problem to configure my 7750 SR to send cflowd packets on public IP, it keeps sending through private IP.
Thanks!
