Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Disk Usage Alert Macros
bleearg13
Hi all,
I have read through the Alert Macros section and am having problems with getting Alerts to send the data I want for Disk Utilization.
I have an Alert set up to notify me if a Disk on a server is more than 90% full, but I cannot figure out which macro is used to send the value found during polling. For instance, I want my message to appear as such:
Alarm - Disk usage on ${NodeName} is over 90%.
Utilization = xx%
${Date/Time}
How can I display the value of 'xx'?
TIA,
eric
Find more posts tagged with
Accepted answers
All comments
Kaj_Lehtinen
Try using ${PercentUsed} - think it only works in Orion 6.4 and later though.
/Kaj
Network_Guru
It's in the on-line help dox:
<www2.solarwinds.net/.../SystemManager.htm>
Specifically here:
<www2.solarwinds.net/.../Alert_Macros.htm
I find the web dox are more up to date than the local help files
in Orion. I think you can even change the help file location to
point to the on-line web admin files.
-=Cheers=-
NG
bleearg13
Thanks a lot - I guess I should use the online help docs instead of the local ones.
-eric
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
