I find out there are a lot of new status of interface in NPM 10.1 occasional.
Like the following ones. Does anybody know what kind of status those status represent?
unreachable is if a node that you defined as parent is down, therefore the child is considered unreachable and not down (to suppress multiple alerts).
this also applies to some automatic parent/child connections, like when a node is down, the applications are unreachable.
I would still like to know what Dormant, Testing, etc. all mean... if I filter for it in views it seems just like a mess, most of these tags dont filter for what they say they filter for
hehe7nic,
Many of these states are explained in the SolarWinds Orion NPM Administrator Guide. A list of states listed from worst to "best" is also provided in the section, "Status Icons and Identifiers > Status Indicators" of the SolarWinds Orion NPM Administrator Guide.
The main ones with which you might be concerned are as follows:
What's the difference between 'Unreachable' and 'Unknown'?
I want to know what Dormant, testing, too.
hehe7nic--
Did you check the "Status Icons and Identifiers > Status Indicators" of the SolarWinds Orion NPM Administrator Guide yet like pacetti suggested? You may find it there.
M
