when moving from network traffic analysis to network performance monitor, i get the login screen again. is there a fix for this?
also is it possible to change the refresh time for NTA?
Mick,
I haven't seen this issue with the NTA, but I have seen it when users log into the Orion site by IP address and then try to navigate to a custom menu item on a customized menu bar. I created a CNAME record in DNS (I called it Orion) that points to the fully qualified domain name of the Orion server. I then made sure the links for the custom menu items pointed to http://Orion/whatever instead of the server name.
I just installed the NetFlow module and am trying to get it working on our additional web server, so I can't answer your question about changing the refresh time for the NTA.
Hope this is helpful.
Kevin
thanks Kevin
ive checked this out and DNS entries are setup.
i think the problem is the NTA page times out. i notice if i leave it open a while then refresh, i have to log in again.
I think that I understand your scenario. You are indicating that if you leave an NTA page open for a time period over 20 minutes or so, that when you hit refresh, it will show the login screen again?
If so, then yes when your session times out, the login screen will come up again. This is normal behavior for web pages.
Yes, that is the problem.
Is there a way I can adjust the time out setting for this page. I want it to stay open the same way NPM does.
thanks
Orion NPM 9.0 ships today, and one of the features of 9.0 is the ability to set your session to never time out. This is done on an account by account basis, so go to the account settings after you upgrade to 9.0.
