Cant seem to get the installer to finish..has error that NTA database is not an Orion NTA 3.1 database..you must install 3.1 before installing 3.5 upgrade.....
What do I need to do to get this eval running?
Hi Bryan,
This happens when 3.5 is installed on a machine or database that had pre 3.1 NTA installed in the past. Support can fix this quickly with a ticket.
Andy
Thanks Andy...I will work with support on this. I had done an eval of NTA a while back and that must be causing the issue.
Also, just FYI, we're working on making sure that the "ghosts of evals past" issue is resolved in future Orion releases.
I have been experiencing the same issue, so far no luck. Any update on this?
You'll need to contact support to get the workaround.
