Hey I just noticed the Argyle Socks and the Zip-up Jacket cost the same number of points. Somehow that seems wrong Is the argyle pattern copyrighted or something?
I have the socks. Great colors but not the best quality. If I could choose again, I would get the Zip-up jacket. The number of points for all their socks should be between 6-8000.
I have the jacket... love it... and have gotten compliments on it as well.
gsutherland@sharoncu.com
Do you know what brand the jacket is? I'm trying to get an estimate on the size of the jacket, since they don't have XXL.
port authority
is the zip up jacket, fleece? Is this the jacket they use from port authority - Port Authority - Product Details - Mens/Adult / Outerwear - F227
It's definitely not the link you provided, since the jacket is not two-toned on the arms and is not 100% fleece.
The jacket is 100% polyester and has a pretty rough/durable outer texture. It's much heavier than a normal all fleece jacket by far and that was the first thing I noted when I took it out of the package.
I ended up giving this to my boss, since we work in a datacenter.(sub-arctic temperatures) I was hoping for something similar to a northface, where it's all fleece, but that doesn't appear to be the case.
I can upload some higher res images, if you'd like.
-R
Thanks for the reply. Yea if you have time for some high res pics that would be great. What size did you get. I am 6'3 and have long arms so trying to gauge if XL would have long enough arms for me. If you have XL would you measure the length from the shoulder stitch to the cuff?
I wonder if its this one Port Authority - Product Details - Mens/Adult / Sweatshirts & Fleece - F222
I had to upload them to a Imgur Album, here you go: Solarwinds Jacket
The port authority photos do not show enough detail for me to correctly identify the jacket.
great thanks for the photo's. Nice quality pics, really shows the jacket's material. I ordered one
