I have the same problem running Orion NPM SLX 9.1, it can now take up to "4" hrs to complete the DB maintenance that kicks off at 2:15 AM and the graphical chart data is now totally missing during that time. We also are a 24 x 7 environment so that data is vital. Solarwinds team, what steps are being done to correct or is there something we can do to correct the problem?
We fixed a DB maintenance bug in SP1. Are you running SP1?
I will give SP1 for 9.1 a try, I had not yet installed that service pack thanks for the tip.
I installed the SP1 for 9.1 and now the DB maintenance runs in 10 min, and no deadlocks.
thanks!
Thanks for the assistance,
Mark
SP2 won't do anything more in this area. If you'still re seeing gaps in your data during maintenance, it might be that you're database is stretched to its limits and the database maintenance "pushes it over the top" so that when the DB is being groomed, it's too busy to accept new data. That's the usual case when folks see gaps for DB maintenance.
Thanks for the update
