Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Nest Maps
Marketta
If any one read this and knows the answer, exactly how do you make submaps on MapMaker to be shown on the internet browser page?
Find more posts tagged with
Accepted answers
All comments
Cygnuz
I did in this way:create the subview with a map(let call this a sub map), copy the web url for this view. Go to the map maker, create the new map then add an object, edit property for the object and map it to the sub map, edit the web link for the object and past there the URL link.
mjhamilton
this is quite simple really... just create you maps as separate items within the tool and simply create an object (i.e. UK flag for UK) and then edit this new object and add the relevant map as its active agent.....
So when you click on the UK flag it will take you to the relevant map that you created in mapmaker.
Good luck
Martin J. Hamilton... lost in a sea of snmp...
Isaac
Hi Marketta,
When you are working with a map in map maker you simply drag another map on to the map you wish to have as the 'parent'. This requires that you create your 'child' maps prior to creating the map that will act as the parent or top map in the nest.
Hopefully this is clear. If not send me an email and I can detail the steps fully.
Be fantastic.
Mithrilhall
Correct me if I'm wrong but...
Just create you top level map.
Now, create a sub-map.
Then, drag the sub-map onto the top level map.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
