When generating a trap with Orion, are they SNMPv1, v2, or v3? Thanks.
Anyone?
It's specified in the corresponding rule file that is being used at the time. The default is SNMPv2.
Can that be changed to SNMPv1? Also, what is the corresponding rule file, and where can I find it?
anyone?
SolarWinds does not support the direct editing of rule files. It is recommended that you create your own rule and set it as desired.
I've checked further and found that SNMPv2 is the only version we currently support for Traps.
