Anyone using Eminentware to update their Adobe Acrobat products?
I am going to being creating packages and would like to know if anyone already "been there, done that"
Thanks again.
Patrick Moore
pat.moore@state.mn.us
Hi Patrick,
Yes, others have used EminentWare to update Adobe Acrobat products. We include pre-built packages for Acrobat 9.x as part of our 3rd Party Updates Pack. A complete list of available packages is here:
https://www.eminentware.com/cs2008/media/p/719.aspx
Adobe does also have an Acrobat 10.x catalog available; it is available here:
http://armmf.adobe.com/arm-manifests/win/SCUP/Acrobat10_Catalog.cab
-Kelly
Thanks Kelly. I am very excited to learn of the Adobe Acrobat 9 updates.
I am specifically looking for Acrobat 7.0 products, in particular Adobe Acrobat 7.1.0 cumulative, 7.1.3 and 7.1.4
I was able to create those packages using the .msp files for all three Adobe Acrobat updates and it works like a charm.
At least my boss is happy.
I did get a small error message about signed applications when publishing the Adobe Acrobat 7.1.0 cumulative but it does seem to install on systems anyway.
Is there a reason that their 10.x versions aren't in the 3rd party pack? Win7 kind of wants us to install the latest and greatest...
I downloaded the Adobe 10 catalog and that seemed to work fine importing into Emientware. I think Adobe made the catalog available for products similar to Eminentware like SCCUP(sic) and such. Just my 2 cents.
