I have several 2510G-48/24 switches, I am finding some bizarre results when trying to download the startup-config. Does anyone have a device template for these switches?
I have tried the 2810 template to no avail...
Many thanks in advance
CuppaT
Apologies,
I thought I had uploaded this already! I have done it now -
Cheers
Please upload a session trace and we'll take a look to see what's going on.
Hi Chris,
Thanks for your response, I figured out my problem, I was requesting 'startup-config' in the device template instead of 'config'.
Many thanks for your reply though...
CuppaT, glad you were able to work it out. When you get a chance, can you please upload your device template to the content exchange area?
Hi Cupp do you happen to have a device template for HP 2510 24 and 48 ports? Because I'm having an issue. I cannot download the config via snmp. I need it to run in snmp and not tftp. I cannot seem to find suitable template for our devices. I appreciate if you could lend us ur divice template.
Many Thanks,
Roselyn
Will it work for HP2510-24 ports? I'm having a problem with using the device template. I have downloaded some templates and ended up with downloading errors. It says it's not a cisco device. I'm using snmp-tftp instead of telnet since we're using tacacs. I just change the OID and placed it on the device types folder. I'm so desperate...
