Does Orion Wireless module work with Blue Socket Wireless AP's and controller? (www.bluesocket.com).
Thanks in advance,
Harry
If it it's a model with "thin" APs and a controller, then not this version.
There are a lot of thin client AP's and controllers. When do you think Orion will support this type of wireless infrastructure? Are there any thin client types of wireless implementations that are currently supported by Orion?
We're trying to decide that now.
It's been a while and I am revisiting some of our network issues. Has Solarwinds added anything to Orion NPM to monitor the Bluesocket thin access points and controllers? I would really like to do more monitoring then just an IP ping.
Would like this as well.
Any updates on Bluesocket Controller/Access Point monitoring support?
