I need to develop a template that will give me the detail below:
1. In Single VLAN, how many ports are configured/used in whole environment.
I will appreciate any clue to this.
Thanks.
If you have inventories running you should be able to pull that right out of the database with a report. Try the query below in a report (or Custom Query resource) of type SWQL:
SELECT EntityID, VLANID, VLANName, VLANMTU, VLANType, VLANState, NodeID, LastDiscovery, FirstDiscovery, MissingFROM NCM.VLANs
To get a count of each VLAN:
SELECT VLANID, COUNT(1) AS QtyFROM NCM.VLANsGROUP BY VLANID
Sample output:
Steven W. Klassen
Programmer Analyst @ Loop1 Systems
http://www.loop1systems.com/
http://www.linkedin.com/in/mrxinu
Thank you so much for this insight. It there a way I could add third column to contain interfaces assigned to the vlan across the environment?
Your input is really appreciate.
regards,
You're very welcome. Give this one a try:
SELECT n.NodeCaption, n.AgentIP, i.InterfaceName, i.VLANIDFROM NCM.Nodes nLEFT JOIN NCM.Interfaces i ON n.NodeID = i.NodeID
Can you assist on why I am having an empty report after I have run download job?
Or am I missing any steps?
Did you run the inventory job? I believe that's where this information comes from.
Thanks I was able to get out this..
I also need this to include non forwarding interface i.e both administrative down interfaces and non connected interfaces.
Any help on this?
Thanks for your time.
What query produced what you've got there?
I use one builtin report templates. I am having issues generating report with SQL I am newbie in SQL.
Can you guide me please?
Here is something close to what I am looking for. I used web builtin report. But it read no activity to report. Any ideal why?
Regards,
I would check the Data source and see if the rule is there correctly. Below is a screenshot of what is should look like, though it should be this as default. I believe the report also runs off of the configs in NCM so if your nodes do not have a backed up copy of the configuration that may be why there is no activity to report. Can you check in your NCM instance and see if you have any configs back up?
