I just noticed the same thing with my servers. This is happening on 10 of my Windows servers.
Are you running 8.5.1 SP3? We had problems with Windows 2000 servers flatlining at 100% CPU. Looks like the issue has finally been resolved in SP3. We've been running 2 weeks on SP3 and CPU is now looking good on our 2000 servers.
I applied ServicePack 3 last night on all of my pollers and web server, but I am still seeing the same thing. Will this go away with time? I am guessing it is not going to fix last month's reports?
I think this is because the MIB orion uses for memory lumps physical memory and swap space. If a device has 100MB of physical memory and is using 90MB, then the percent memory used will be reported as 90%. If it is using 100MB, then percent memory used will be reported as 100%. However, if the device is using 100MB of memory (all of it) AND 50MB of swap space, then the percent memory used will be reported as 150%.
I seem to be having the same issue. I'm monitoring some Barracuda appliances (spam and content firewalls) and they are registering 150% + CPU usage. These really aren't critical for me to monitor, so I chalked this one up to an anomaly and ignored it.
Does this explain the problem though? I can understand with memory, but CPU usage doesn't seem related to the explanation.
