Hi team,
Has anyone created the report on Parent Child dependency, Following SQL query uses the ID and not name of the node.
SELECT TOP 1000 * FROM [dbo].[Dependencies]
Please help if anyone has done it.
Prashant
It would be nice to get a canned report. I have been experiencing issues with dependencies and would like an easy way to compare the different configurations.
So this can be a bit messy because of all the scenarios where basically any type of object can be a parent to any other type of child object type. Going to have to play with some case logic to make this into less of an unreadable mess....
Ok so this is as far as I'm going to do the leg work on this because I expect it will take care of 90% of use cases. Feel free to follow the model and add on if you need one of those other cases.
Also, the replace() function is brand new in Orion Platform 2017.3 (NPM 12.2) and later, if you aren't up to date then just use the commented version of the parent and child lines instead.
SELECT d.Name as [Dependency],Replace(Replace(Replace(d.ParentEntityType,'Orion.',''),'SEUM.','WPM '),'s','') as [Parent Type] --,d.ParentEntityType as [Parent Type],case when np.caption is not null then np.Captionwhen ap.Name is not null then ap.Namewhen gp.Name is not null then gp.Namewhen tp.Name is not null then tp.Namewhen ip.FullName is not null then ip.FullNameend as [Parent],Replace(Replace(Replace(d.ChildEntityType,'Orion.',''),'SEUM.','WPM '),'s','') as [Child Type] --,d.ChildEntityType as [Child Type],case when nc.caption is not null then nc.Captionwhen ac.Name is not null then ac.Namewhen gc.Name is not null then gc.Namewhen tc.Name is not null then tc.Namewhen ic.FullName is not null then ic.FullNameend as [Child]FROM Orion.Dependencies dleft join orion.nodes np on np.Uri=d.ParentUri --Nodesleft join orion.nodes nc on nc.Uri=d.ChildUrileft join orion.apm.Application ap on ap.Uri=d.ParentUri --Applicationsleft join orion.apm.Application ac on ac.Uri=d.ChildUrileft join orion.Groups gp on gp.Uri=d.ParentUri --Groupsleft join orion.Groups gc on gc.Uri=d.ChildUrileft join orion.seum.Transactions tp on tp.Uri=d.ParentUri --Transactionsleft join orion.seum.Transactions tc on tc.Uri=d.ChildUrileft join orion.npm.Interfaces ip on ip.Uri=d.ParentUri --Interfacesleft join orion.npm.Interfaces ic on ic.Uri=d.ChildUriorder by d.Name--to do--Player Locations--AppInsight for Exchange: Applications--AppInsight for IIS: Applications--AppInsight for IIS: Application Pools--AppInsight for Exchange: Databases--AppInsight for Exchange: Databases Copies--Database Instances--LUNs--AppInsight for Exchange: Mailboxes--AppInsight for IIS: Sites--AppInsight for SQL: Databases--AppInsight for SQL: Applications--Transaction Steps
-Marc Netterfield
This is giving me an error that "* Query not valid"
I get the following error in SWQL Studio. "Source Entity [orion.seum.Transactions] not found in catalog"
Do you have SEUM (WPM) in your environment? if not then just delete any lines referencing those tables
This worked for me on Orion version
SELECT d.Name as [Dependency] ,d.ParentEntityType as [Parent Type] ,case when np.caption is not null then np.Caption when ap.Name is not null then ap.Name when gp.Name is not null then gp.Name when ip.FullName is not null then ip.FullName end as [Parent] ,d.ChildEntityType as [Child Type] ,case when nc.caption is not null then nc.Caption when ac.Name is not null then ac.Name when gc.Name is not null then gc.Name when ic.FullName is not null then ic.FullName end as [Child] FROM Orion.Dependencies d left join orion.nodes np on np.Uri=d.ParentUri left join orion.nodes nc on nc.Uri=d.ChildUri left join orion.apm.Application ap on ap.Uri=d.ParentUri left join orion.apm.Application ac on ac.Uri=d.ChildUri left join orion.Groups gp on gp.Uri=d.ParentUri left join orion.Groups gc on gc.Uri=d.ChildUri left join orion.npm.Interfaces ip on ip.Uri=d.ParentUri left join orion.npm.Interfaces ic on ic.Uri=d.ChildUri order by d.Name
Strangely, I get Query Not Valid for both scripts. By the way, I tried to fix the problem by replacing Orion by SolarWindsOrion which is the name of our DB. Still, neither of these queries worked for me. Any ideas?
If you are referencing the name of the database then I'm assuming you are trying this as SQL, it's not SQL it's SWQL. You would put this into a custom query resource or use a custom table resource with the custom data option set to SWQL.
My original version assumes you have NPM/SAM/WPM but the version posted by tedapap will work with just NPM/SAM and also works for older versions if you don't have 2017.3 installed yet.
Whenever you run into issues executing custom SWQL your best bet to troubleshoot it is by loading SWQL studio and trying it there because it gives far more descriptive errors than just saying it's "invalid"GitHub - solarwinds/OrionSDK: SDK for the SolarWinds Orion platform, including tools, documentation, and samples in Powe…
Does the node to node link report that you can create not give you what you want without having to create SQL for it?
