Any idea please. I am having error in monitoring MySQL in SAM 6.1.
"ODBC data source returned an error. [MySQL][ODBC 5.1 Driver]Access denied for user 'username'@';x.x.x.x' (using password: NO)."
Thank you.
if you get an error message that contains using password: NO, it means that you tried to log in without a password.
using password: NO
Hi, Thanks for your response.
This is what Im clarifying also with SolarWinds support. The database admin of the MySQL didnt set any password thats why we leave it blank.
Do we need to asked them to set a password for that account? Please advise. Thank you.
Yes, a password is required.
May I know if MYSQL version 5.6 is supported for MYSQL template?
Regards,
Manilyn
Yes, this template should work with MySQL 5.6 without issue provided the appropriate corresponding ODBC driver that is compatible with MySQL 5.6 is installed on the Orion server
