That link is dead, can you provide more information on this. I would like to use putty for my Orion site.
Thanks.
Link has been updated -
I've attached the zipped Reghack file for your convenience.
I have asked for this feature for awhile now. Like Cirrus you should be able to define custom tools to use. You should be able to remove those icons, or add icons that can be used for SSH, etc. BB
has there been any progress from solarwinds on this? I dont like having to "hack" the registery or anything like that to be able to support SSH to my devices.
