Has anyone had any success configuring pollers for the Dell Poweredge 2950? All the literature I find so far points me to the 1.3.6.1.4.1.674 OID tree, but every OID I test in the UnDP comes back not supported.
Any ideas?
Someone created a UnDP for a PowerEdge here you might look at for reference -
I had already tried that one and a bunch of others from the same region of the Orion MIB database. None of them return any data. This particular one returns a result of "A value was not returned".
Any ideas what is going on?
I do custom polling on all my PE servers. Service Tag, model number Bios version etc. However in order for it to work Dell Open Manager needs to be installed.
Freemen, have you had any further luck with this. I have couple of 2950s as well.
You need the Dell OpenManage Server Administrator software. It's a free download from Dell's website. It contains the necessary software so you can monitor the server via SNMP. I downloaded it for my three Dell 2950s and I can monitor all types of hardware on the server. Install it on each of your servers you want to monitor. Here is the link - http://ftp.us.dell.com/sysman/OM_5.2.0_ISM_A00.ISO
afarmer, I'm just curious as to why you used 5.2 and not 5.5?
