I am looking for clarification
We have the NPM plus 2 additional pollers
Hot fix 3 says clearly that it goes on both the NPM and additional pollers
I am unclear on whether hot fix 1 also goes on the additional pollers or not.
Best practice for SolarWinds software, keep everything on the same rev. If you apply a hotfix to the main server, apply it to the pollers as well.
OK so I have downloaded hotfix 1 and hotfix 3... what happened to hotfix 2???? It's not a choice.
Radionman
It's now included within hotfix 3. I believe the same file is changed.
It's not apparent, if hotfix 2 is added to 3, why not just FIX the 10.4 Release and be done with it, I have to load this stuff on 12 servers. it's a pain.
Radioman
They have 10.4.1 in RC phase currently so it looks like they are moving toward that. I understand, though, the pain that comes from upgrading that many servers.
