hi i enable the PortScans Rule and its firing but when i enable the other like Attach USB Device rule its shows in the monitor but the rule can't fire.
please help me on this.
This KB might help you troubleshoot: SolarWinds Knowledge Base :: Troubleshooting LEM Rules and Email Responses
Also make sure the 'Activate Rules' (Build > Rules) button has been clicked after you created your new Rules
Thanks for your help, i do all configuration, and check the link also but after that i can see the LEM Internal Events.
But the rules are still not firing.
Please advises me
Event Name EventInfo InsertionIP Manager DetectionIP InsertionTime DetectionTime Severity ToolAlias InferenceRule ProviderSID ExtraneousInfo
InternalAuditSuccess admin - View User swi-lem swi-lem 192.168.0.123 5:18:31 Wed Nov 25 2015 5:18:31 Wed Nov 25 2015 2 auditing yXE07428l7cKXEXDwGiS6UEAF0k=
is the Activate Rules button grayed out?
The only other common reason why rules don't fire is because the LEM Manager time is not synchronized. So, the event timestamps would fall outside the 'Response window' of your rule definition, and hence wouldn't fire.
You can infer time mismatch issues from the timestamps of the internal audit events that you see under the LEM Internal Events filter and the events for which you are trying to correlate
When you connect a USB Device to one of the LEM agent nodes - can you see that event within the LEM Console?
The event should appear in the Monitor section under IT Operations > System Events:
If the event is not appearing - that would be the cause of the rule not triggering & it could be an issue with the USB Defender.
HI
When I connect a USB Device to one of the LEM agent nodes, i see that event within the LEM Console.
But i don't see the email event or rule fired or not received any email.
Ok cool.
Can you edit the correlation rule to look like this - i.e. add the Provider *USB* condition and also adjust the response window to 5 minutes? Can you also make sure to click Activate Rules on the main Build - Rules page?
Is the timezone and date/time correct?
If not, use TZCONFIG in that context to fix the time zone, or use DATECONFIG to fix the time.
could you send me screenshot of the rules you created to catch user modifications/updates/adds
i am having a terrible time getting my filters/rules to catch any user modifications/updates/adds within AD
thank you in advance!
