We are using traffic light icons in our maps. Some appear normally, and some have small green circles in the lower right corner. What makes that circle appear?
Any help would be greatly appreciated.
Without actually seeing your icons, the small green circles in the lower right corner sound like status indicators for child interfaces. If
Here is our current map. For example, Waldwick and Dumont both have one child object up and running, but only one icon has the circle present.
dbaker228,
Can you try to upload your screen-capture again?
Sorry, that was a cut and paste.
I'd suggest you open a support ticket, so we can get someone to look at your specific environment.
