Is there any way to add asset inventory via SWIS? Like using create or invoke methods. If possible, can you give an example?
I try this code but got that error, "Entity Orion.AssetInventory.Polling does not contain any key properties. Parameter name: entityType"
swis.Create("Orion.AssetInventory.Polling", new PropertyBag
{"EntityType", "Orion.AssetInventory.Polling"},
{"NodeID", pai.NodeID},
{"PollingDescriptionName", pai.PollingDescriptionName}
Programmatically configuring Asset Inventory is not supported right now. We have an internal ticket to add it as a feature. The ticket number is 348041 if you want to check on status in the future.
Thanks for reply madhavan,
I will wait to supporting this feature. I hope it will be asap.
Was there ever any update to this ticket?
Did internal ticket number 348041 ever see the light of day?
No update here. This is still not supported.
Sooooo is this supported in 2018 ?
No, it is not.
Still not on the radar for 2019?
From what I can tell, this is not supported yet. The internal ticket number is now SAM-7966 instead of 348041.
