I uninstalled NMP from a windows 2012 server and now it will not reinstall. Does anyone knows what I am doing wrong?
Please assist!
You didn't mention any errors or specific issues.
Here is a generic uninstall procedure: http://www.solarwinds.com/documentation/en/flarehelp/npm/content/npm-uninstalling-npm-sw1446.htm
This is a general uninstall procedure, and it may differ slightly from version to version.
SolarWinds recommends to use this procedure when installing daily builds for testing.
regedit
HKEY_LOCAL_MACHINE > Software
C:\Program Files (x86)\SolarWinds
C:\Program Files (x86)\Common Files\SolarWinds
C:\inetpub\SolarWinds
C:\ProgramData\Solarwinds
C:\ProgramData\SolarWindsAgentInstall
Thanks for your prompt response d09h, I did some of your instructions before and also some folders wont delete.
When I start installation, the yellow starting installation window pops up and then disappeared....that's it! nothing happens after and nothing is installed.
I am thinking if this is windows 2012 thing......the last one I used was 2003 server...this is really new interface and a few new features for me.....
still at it.....
I think it would be helpful to post any error messages you can find.
None!!! no error message......installation starting window just goes away and that's it...
https://support.solarwinds.com/Success_Center/Network_Performance_Monitor_(NPM)/Troubleshoot_SolarWinds_Orion_installation_issues_with_Active_Diagnostics
Sure, I did download a fresh copy but no joy.
Do you have NCM?
yes i do.....but not installed yet.
You uninstall Node.js and NPM the same as you would most Windows software:
modem wifi password
Now, here is what is going on....when the installation start extracting files into the temp folder, I see it populate the folder with installation files and when the installation stops all the files disappeared!! I tried to copy some files and installed NPM, but I get an error while trying to run NPM configuration wizard....
* No valid package combination was found for your system
I believe this is because I copied the installation files manually....how do I fix this?
