How can I script the enabling/disabling of certain monitors? (ideally using Powershell, but other scripting languages will work as well)
I would recommend using a maintenance schedule. You will not need a script, and you can set start and stop times.
How would that work exactly? I wanted script commands because the monitors need to be enabled/disabled after certain steps in software deployments are completed. It won't be the same everytime.
You would need to submit a feature request to get this functionality added.
What about the SOAP interface? Can I access that with Powershell?
SOAP is no longer supported in the later versions of ipMonitor.
