Is posible create an alert of Event Viewer System.
e.g.
Type= Error
Event = 1111
Hi neleducarco welcome to the forums. To be able to alert on Event ID's you would require the Server & Application Monitor module.
You can either use the Out-of-Box template (I think it's called 'Errors in Application Event Log') and modify/rename it
Or you can create your own template and add the 'Windows Event Log Monitor' component to it.
Hi dgsmith80, I'll do, my comments soon if it work or doesn't work.
On Orion platforms it can be do, or it is necessary the Event log monitor? dgsmith80
Sorry, I'm not sure I understand your question?
What I'm trying to tell you or explain to you is that, I don't have the event log monitor module, it's possible to create this type of new alerts, by the alert manager \ add new alert?
Ah sorry - So that screenshot is from the Server & Application Monitor (SAM) you need to have that module in order to monitor the Event Logs. Do you have that module?
You have to apply an Application Monitor to the Server you want to watch for that Event Log on, and then you setup the alert.
