Should SAM 5.0.1 hardware monitoring have visibility to memory in HP BL460 G7 blades? I'm seeing Fan, Power Supply, Temp, Disk, Battery, Array and CPU, but no memory info.
David
This was fixed as part of SAM 5.2 which is currently in Release Candidate. If you'd like to participate in the RC you can sign up here.
My BL460c G7's do not show memory under the current hardware health resource. I do have RAM utilization under the volumes resource. You could add a universal device poller for it.
Hey Blue,
Thanks for the reply. Right, I know I can use Universal Device Poller to get the info, but really, this should be included in hardware monitoring. Obviously, HP has sensors for it, so I'm curious if it was left out, why?
Listed as a fixed issue in SAM 5.01 but maybe it takes an uncheck and recheck of the Hardware Health to take affect - let me try that and add the same node to my 2nd Orion system to see how it acts?
-Update -my BL460c G7, G6, nor a DL380 G6 work in either SAM 5.01 while my DL380 G5 does show memory in the current hardware health resource.
SAM 5.2 did the trick. Thanks!
