Hello,
What "trigger condition" should I use to make Alert Manager send emails when a port status changes to Err-Disabled for any reason ?
Thank you.
Interface = not up
That doesnt work
Interface = not up = any other reason (Down/Warning/Shutdown/Unplugged/Testing...)
I'm looking for something to trigger when Err-Disabled activated only.
From Network Guru
You should be able to use the Syslog Alerting to notify you when a port goes into error-disable stat.
Here are some examples of the e-mail alerts I have configured:
ERROR: %SPANTREE-2-BLOCK_BPDUGUARD: Received BPDU on port FastEthernet2/17 with BPDU Guard enabled. Disabling port.SEVERITY: Critical
HOST: 10.10.100.1ERROR: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0009.be0d.18e7 on port FastEthernet4/8.Orion QuickLink:Orion/.../SearchNodes.Action.asp
"%IP-4-DUPADDR: Duplicate address 172.31.28.179 on Ethernet0, sourced by 001a.8cb9.46a5"
ERROR: %RTD-1-LINK_FLAP: FastEthernet0/9 link down/up 6 times per minSEVERITY: Alert
ERROR: Jul 16 21:16:37 PDST: loopback error detected on Fa0/1, putting Fa0/1 in err-disable state
I've been using Syslog alert, but still searching for a way to do it with Alert Manager, its more flexible for me that way. I've searched the forum and saw someone else has asked for the feature since 2008. I guess SolarWinds still have no plan to implement this useful feature.
there is another post somewhere that shows that Solarwind currently only knows about up/down states.. It doesnt know what "Err-disabled" is, so its not an option in the advanced alert manager. I think when they finally integrate Syslog/Traps into Orion, we will be able to do this - I know I am looking forward to that day.
Syslog alerts are currently the only way, unless you create a custom poller to check the numerical equivilent.
