Hello all and thanks in advance for your help,
I came across this one device and noticed that NPM lists this router as having interface G0/3, but as you can see from the router output... there is no such interface G0/3.
Thanks!
The interface list shown when you click on 'list resources' is the result of a real-time SNMP query. So, it should be straight up from the SNMP ifTable. You can do a mib walk to using the snmpwalk.exe or universal device poller to cross-check what the device is telling you via SNMP.
This is an interesting one...
I did an snmp walk (thanks HolyGuacamole) and the walk is picking up G0/3 from the device. It is accurately being listed in SW as a resource, but this interface does not appear anywhere on the device it self. Hmmmm.
Which device is it? Which command did you run on the device?
This is a Cisco 2911. issued 'sh int status' sh ip int br' 'sh hardware' 'sh int'
Just curious. Did you ever solve the mystery? Did you end up opening a ticket with Cisco?
