Hi!
Tell me please, support server "reverse connection" via the command line.
Thank you.
Hello,
This is not currently supported with our existing command line switches. You can find a complete list of supported command line switches here:
Mini Remote Control Command Line Switches
-Craig
Thanks for the answer.
It's not quite what I meant.
I need to do "Reverse Connection" from the server used by the client (dwrcs.exe).
I want to make the client (dwrcc.exe) run the mode "accept incoming connections", and the server (dwrcs.exe) to be launched in the "Connections to client."
And all this through the command line.
Got it. If I understand correctly, you want to be able to initiate a connection from the machine where the DameWare agent (what you're referring to as the client) is installed, and you want to do this through the command line. Did I get that right?
Yes, that's right. Currently I have written a wrapper for the remote control on RFB protocol to realize the function of reverse connection. But there are some problems with the launch of a service system. I can not pass control to the client log off. It would be desirable to have alternate methods of connecting.
Understood. As I mentioned previously, this use case is not currently supported. Are you familiar with our 'Ideas' forums? I would recommend posting your idea there as a feature request to see if other customers are interested as well and willing to vote for it.
DameWare MRC Feature Requests
