Hello;
Is there a way to tweak the NTA Graph to load faster or something?
What are the dependencies for this module (ei : IIS)?
Thank you
Which version of NTA? The screenshot looks like NTA v4.x. Assuming 4.x, is your NTA server on a 32 bit machine or a 64 bit one, i.e., are you still storing the NTA data in the SQL database or the new FSDB (Flow Storage DB)?
Hi!
4.0.3
64 bit
own db. - same as orion
FSDB
What are we looking at in the screenshot above? Is this data from all of your sources, or a specific netflow enabled interface?
If you look at such a graph (top receivers over one hour) on a single interface, is it fast?
This is from all sources - it take like a minute to "render", the data below comes ok, but it takes for ever..
Generally, to improve FSDB performance, it is recommended to move it to dedicated machine, dedicated drive.
