quote:Originally posted by BryanCORRECTION!!!!!!!!!!You are going to enter the VLAN under the SNMP community string section..HOST/IP: 192.168.1.1Community String: Private@99Sorry about the mixupLockheed MartinAtlas V Launch OperationsNetwork Engineer
Solarwinds staff, could give some advice regarding this issue, since i'm having the same errors, with the bridge groups. i don't see IP nor DNS data of the connected clients to the switch.
Layer 2 Log Messages8/12/2011 11:30:27 AM - Unable to download dot1d Bridge-MIB for VLAN x. On Cisco switches using SNMPv3, the context for the VLAN must be added to the group using the 'snmp-server group <groupname> v3 priv context vlan-<vlanid>' config command'
the context parameter WAS added...
I would start with the basic troubleshooting: did you try using SNMPv2? Did it work? Can you try MIB Browser to get dot1d table using SNMPv3 and SNMPv2 with the context of VLAN "x"? In snmpv2, the context (VLAN ID) is added to the community string using "@". For instance, to get the data for VLAN #2, use community string public@2. In SNMPv3, fill the Context in the credentials with the VLAN ID.
If you are able to get the data from the table using SNMPv2 and not SNMPv3, the issue is most likely in the security settings.
You can also open a support case and let us do the troubleshooting (please reference this thread when opening the case).
Thanks, i will verify.
but please let me know what are you refering when you said: security settings. whose security settings.? thanks in advance
I meant the security settings on the device. SNMPv3 provides some kind of access control. You can specify special views for different users.
