Folks,
I was wondering about this. I would want to restart a windows service when Percent Memory Used is greater than 90 %. Is this possible?
I have tried to use APMServiceControl but it does not execute it.
Thanks!
Could you pass on the syntax or command you used to restart the same ? What kind of alert have you set up ? APM Component alert ?
Hi Vinay,
APM\APMServiceControl.exe <ServiceName> -c=RESTART
I know from some documentation that the servicename should be the ${ComponentId} but i was wondering if it will be possible to use the <service name> instead of the ${ComponentId}? Or is there a way to call a batch file instead?
The component ID is required because SAM needs the credentials used to monitor that component to restart the service. The Component ID can be a macro as the OOTB alert uses to restart failed services, but it can also be entered manually to restart a specific service on a particular node when the trigger condition is met.
May I ask if the ComponentID is the same for all node? For Example, i have the same service name in 2 server for example vmtools, the component id for vmtools are the same for servers?
I think i found a solution. I'll test it tonight.
The Component ID is globally unique. E.G. unique for each component monitored by the system. That means per-server, per-application, per-component. The Component ID can be seen in your browser when you're on the "Component Details" view. The Component ID is the number following "AM:" as shown in the following screenshot.
